| | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#98847 01/14/2007 7:14 AM | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | HI...parking lights work...turn signals work...bulbs new...stop light switch depreses...fuse ok..but step on brake no stop light I got it this way from PO who painted all the wires black on the firewall...push horn button and all I get is a tump tump noise...HELP! Thomas Edison I'm not..we thank you for you time, Steve | | |
#98848 01/14/2007 7:35 AM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Could be that the stop light switch is dead. Does it have a mechanical or hydraulic switch?
Also you wouldnt believe how dirty connections and rusted grounds will make things not work. Take a little time and follow some of the wires and make sure there arent any broken or loose connections.
I got ****** at mine and decided to just rewire the whole darn thing. Works good now! | | |
#98849 01/14/2007 3:59 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | A new wiring harness would probably be a plus. Ditto on rustednuts advise of checking all of your terminals & grounds. You can use a multi-meter to check your brakelight sending unit. If you get power in but not out the sending unit is bad.
#98850 01/14/2007 4:59 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Get a test light & start traceing the circuits. Like Tiny says one term on the stop light switch is hot all the time. When the pedel goes down the other term. should be hot. I don,t know about tump tump but if you get a clicking noise under the hood when you press the horn button it means the circuit is good up to the relay. Again use the test light to see vif any curent is getting to the horn. If not it,s a deffective relay. If it is it,s a bad horn. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#98851 01/15/2007 4:54 AM | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | Start simple, check for bad grounds. Ground the bulb case while someone else depresses pedal. Or use alligator clips to ground if you don't have help. Ditto on the horn, especially with painted wires etc. Good luck. | | |
#98852 01/15/2007 5:01 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Could also be a bad turn indicator switch. Usually the wire goes from the brake light switch to the turn indicator switch, then to the lights. | | |
#98853 01/15/2007 5:12 AM | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Sounds like bad grounds to me. Pick up an electrical test probe light(ice pick with a light)at the parts store. and start checking your taillight wires,etc..... from the firewall back. bet its ground wires!!! Marty (you might want to run a ground wire straight from the batt. to the frame/body) | | |
#98854 01/15/2007 8:37 AM | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Regarding the breaklights, if the turn signals work then the ground should be fine (same filament). I would look to the switch or the turn signal switch may be killing the stop lights as baldy said. You might try jiggling the turn signal handle with the brake depressed while a victom watches for glimpes of light.
The horn does sound like a ground or a bad horn to me. You can make temporary grounds to test this theory. Just give it a new ground using a clip jumper. If you don't have one, make one as this is a great diagnostic tool to have in a shop (12gauge wire with clips at either end). Just clip one end to the ground on the horn, and the other to a good clean metal contact. If it is still weak (thumps) then see if the power side is good enough with the same manual jumper (battery to pos side of course). If it works then, you'll have to look to the wiring inbetween somewhere that is weak. | | |
#98855 01/16/2007 10:09 AM | Joined: Mar 2005 Posts: 37 Junior Member | | Junior Member Joined: Mar 2005 Posts: 37 | What Kind of vehicle?? On some cars/trucks the power for the Brake light switch comes out of the Headlight switch not the fuse-block.
BAN LOW PERFORMANCE DRIVERS... NOT HIGH PERFORMANCE CARS !!
#98856 01/16/2007 4:37 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | you need a test lite and a friend with some ele skill,,,,your thump if coming from horn you need horn,,,brake lites if there are turn signals or no turn signals...doc | | |
#98857 01/16/2007 9:28 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | What year is your truck?
In this discussion it would help a lot to know if it has factory turn signals or an add-on, and if an add-on is it a four-wire or a seven-wire?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#98858 01/17/2007 12:07 AM | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | OK...sorry 1954 3100 rewired to 12 volt by PO nice job....add on turn signal switch lousy job...ground seems fine as lights work. I will check the stop light switch I did not know that one side was always hot..its the old lever mechanical type. I will make that clip jumper and jump out the horns to see if they even work...can I go directly to the battery for a split second? steve | | |
#98859 01/17/2007 6:17 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | if turn sig is wired as it should be brake lite works thru turn sig so you mite have a prob in the turn sig sw wiring..see if you can get a wire dia for it...doc | | |
#98860 01/18/2007 8:46 PM | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | Could be the dimmer switch has a bad connection...after putting in a new wiring harness we found out that the connection in the dimmer pedal was bad...had to do a little wire brushing the terminals....everything works now...I turned my parking lights into turn signals...just waiting on a new radiator....last part.. | | |
