2 members (78buckshot, NJC),
99
Mod | | | Forums66 Topics128,149 Posts1,056,819 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 23 New Guy | | New Guy Joined: Mar 2013 Posts: 23 | Ok I have a rookie question, I installed the back glass in my truck and it is proving to be impossible to get the lock ring in the rubber seal. I have the lock ring side of the gasket on the outside of the truck, is that supposed to be on the inside or out? Is there a trick to installing the lock ring? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, the lock is on the outside ... it can be a job to get in, particularly if it's a poor quality rubber or if the glass is a fraction oversize - there is a tool made for the job that's helpful, which should be available at any FLAPS - a wipe of liquid soap in the groove can help too
Bill | | | | | Joined: Oct 2012 Posts: 60 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 60 | Heat up the rubber in hot water??? | | |
