1 members (TUTS 59), 95 guests, and 1 robot.
Topics128,115
Posts1,056,624
Members48,450
Need some quick info before I make a deal on a parts engine. Is the exhaust manifold used with 250 integrated heads the same as used with the regular heads? If it's the same, will it also work on 292? Any help will be appreciated. Thanks.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
It is different.
Thanks. That's what I thought. After posting I found some pictures on the net that looked different. Looks like I have no need for this engine. Thanks again.
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
You can put the early head on the integral head motor, if that helps.
Larry
I don't own a vehicle that isn't old enough to drink.
