2 members (Bill Hanlon, Steelonsteel), 131 guests, and 2 robots.
Topics128,062
Posts1,055,854
Members48,428
#987937 11/22/2013 4:22 AM
awk
Offline
54, 3100, 235ci. What threaded studs should be in the manifold for the exhaust pipe. Is it 5/16 or 3/8?
awk
awk #987948 11/22/2013 5:34 AM
Its 3/8 available in the "Dorman" selection at your better auto parts store. Theyre usually part coarse thread and part fine thread.
Just ask for a G.M. exhaust manifold stud.
awk #987986 11/22/2013 3:06 PM
awk
Offline
Great, Thanks. I'm missing mine. It just had two bolts and nuts.
The clamps to hold the intake and exhaust to the head, is there a single style clamp on the two ends, if so I'm missing them too. All I have is a stud on the end.
awk
awk #988009 11/22/2013 4:32 PM
1 Offline
The front and rear bolt has no nut nor fastener on it, It is only a guide pin.
awk #988014 11/22/2013 4:43 PM
awk
Offline
Really!!! So the front and rear is only held on, on one side.
Is the gasket all one piece for intake and exhaust. See, I'm missing the two threaded studs for the pipe, so my thought is to remove the exhaust manifold to replace the two studs, but just wondering (haven't really taken the time review the process)if I opening a can worms. Another word do I end up removing intake and exhaust to replace the two threaded studs.
awk
awk #988032 11/22/2013 6:27 PM
three piece gasket set for head to manifold - the silvered gaskets at the top of the illustration.
awk #988061 11/22/2013 8:42 PM
awk
I would. Good time to inspect the surfaces for flatness and check your heat box for leaks.
