4 members (greenie-reddy, pauld, 2 invisible),
85
Mod | | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 45 | 54, 3100, 235ci. What threaded studs should be in the manifold for the exhaust pipe. Is it 5/16 or 3/8?
awk | | | | | Joined: Nov 2001 Posts: 1,523 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,523 | Its 3/8 available in the "Dorman" selection at your better auto parts store. Theyre usually part coarse thread and part fine thread. Just ask for a G.M. exhaust manifold stud. | | | | | Joined: Jul 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 45 | Great, Thanks. I'm missing mine. It just had two bolts and nuts.
The clamps to hold the intake and exhaust to the head, is there a single style clamp on the two ends, if so I'm missing them too. All I have is a stud on the end.
awk | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | The front and rear bolt has no nut nor fastener on it, It is only a guide pin. Jerry
| | | | | Joined: Jul 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 45 | Really!!! So the front and rear is only held on, on one side.
Is the gasket all one piece for intake and exhaust. See, I'm missing the two threaded studs for the pipe, so my thought is to remove the exhaust manifold to replace the two studs, but just wondering (haven't really taken the time review the process)if I opening a can worms. Another word do I end up removing intake and exhaust to replace the two threaded studs.
awk | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Another word do I end up removing intake and exhaust to replace the two threaded studs.
awk I would. Good time to inspect the surfaces for flatness and check your heat box for leaks. | | |
