| | | Forums66 Topics128,037 Posts1,055,576 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | I'm having trouble with the rubber that goes around the column and the brace that attaches to the dash.
I bought a reproduction rubber but it seems too thick and will not allow the clamp to go together.
Has anyone else had this trouble?? Is there a good reproduction out there? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I did not have that issue with the reproduction rubber.
Do you have a shim/washer between the two halves? My 50 did, plus standoff thick washers to bring the column away from the dash. | | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | Yes, mine has one washer on each side between the two halves... but it will not "pull together" enough to make contact. There is still a large gap.
Thanks | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I believe the FAM says to use as many washers as necessary. The clamp should be tight, but I see no harm in adding another washer to each side...or how ever many it takes. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Shop Manual - step 8 - Installation (steering gear assembly): Install mast jacket to instrument panel grommet, bracket and spacers, if any.I would have thought that the spacers are between the bracket and the dash, not between the clamp pieces. red450IP - what part number and what vendor (for the rubber)? There was a 1747-1953 rubber bushing and a 1954-1955st rubber bushing. It has been a while since I worked on a 47-53 steering column, but it should be noted that the FAM mostly shows 54/55 illustrations/parts (this might not make a difference, but it should be noted). | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....when I took mine apart it had thick washers (spacers) between the bracket and the dash. There was nothing between the clamp pieces but the piece of rubber. I believed mine to be original but that's not to say anyone didn't work on the column somewhere along the line. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I think the design of this clamp, as it pertains to the rubber piece and the 120393 PW (washer) is to allow for a prescribed amount of squish (or squarsh, depending on your geographic origin) of the rubber to securely hold the column in place. If your aftermarket rubber pieces do not allow the two clamp halves to touch the 120393 PW when bolts are tightened, I see no reason why adding enough washer thickness between the clamp halves until the halves touch the washers wouldn't be an acceptable solution for you.
