2 members (BC59, Gray_Ghost),
154
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,079 Posts1,056,058 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#98777 01/02/2007 4:18 PM | Joined: Nov 2006 Posts: 33 New Guy | | New Guy Joined: Nov 2006 Posts: 33 | I am rewireing my 49 3100 and found a horn relay mounted on the fire wall, but the replacement wire harness wires the horn direct. It appears that the horn has constant voltage and when you press the horn button you complete the ground. I guess my guestion is did they use a horn relay in 1949?
TIGHT IS TIGHT,TOO TIGHT IS BUSTED
#98778 01/02/2007 4:41 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | bill1949,
I think this might be a gray area. The '48 wiring diagram shows no relay, but of course this isn't your '49. My first thought would be if your rig HAS the relay, and it appears stock, then it came with it.
I sort of thought this might have been a transitional year for the relay...some had them, some didn't.
I have enclosed a link to a thread on this subject earlier in this forum.
Sorry I can't give you a definite answer, I'll bet someone will though.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=000636#000006
Stuart | | |
#98779 01/03/2007 5:58 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | My '51 GMC did not have a relay, but my '53 does. I think someone added the relay to yours in later years when your horn may have had to have repairs. Cecil......... | | |
#98780 01/04/2007 12:16 AM | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | Just shootin from the hip here, but I have seen horns that are grounded thru the body, those require a relay, and then there are those that have a pos & neg terminal, which can be run thru the horn button as the ground side -or- can be grounded & run thru a relay. I've noted that some low power horns are fine to run thru the horn button, but the high amperage blaster horns need a relay so you dont burn out the brush contact on the steering wheel. I'm gonna use a relay either way as I plan on putting in a nice air horn.  1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
#98781 01/04/2007 6:39 PM | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | I don't know if this will help, but my 49 3100 has a horn relay mounted to the firewall. Atomarc is right about the 49 being a "crossover" year. Early 49's used up the last of the 48 parts. For instance, my truck has the later style 4 point cab mounting fastening system, but has the earlier stlye headliner "screw" in bow (?). Which wiring harness did you get?
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#98782 01/04/2007 8:50 PM | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | My '50 3100 does not have a horn relay and I do not believe it ever had one. But it was not working prior to current restoration so this may not be definitive. | | |
#98783 01/04/2007 10:09 PM | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | I had the same wiring question with my 49 GMC. No relay on the wiring diagram, no wires in the harness for a relay, nothing on the firewall. On the other hand the diagram and wires were for a 6-volt system, which mightn't have done any harm wired directly to the horn. But, since the horn wire in the steering column is always on, it seemed like a 12-volt system would burn it out. A relay, using lower voltage, seems like the way to preserve it.
Never start vast projects with half vast ideas.
#98785 01/04/2007 11:35 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 49_chevy_truck,
I sure don't see a horn relay on this diagram.
Stuart | | |
#98786 01/05/2007 2:04 AM | Joined: Nov 2006 Posts: 33 New Guy | | New Guy Joined: Nov 2006 Posts: 33 | Hey Guys
I know that the 49's are a cross over year. I have the 5 point cab mounts, but I have the door weather stipping that is bolted on. As for the horn relay I looked at 3 wireing diagrams and none had a horn relay. I purchased the harness from M&H Electrical.
I changed to 12 volts. Now if I understand correctly 12 volt has more voltage by less ampage and hoping to be able to use the wireing in the steering column.
#98787 01/05/2007 4:14 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | bill1949, The horn will work fine wiring it the way you want...through the steering column sans relay. Be sure to fuse the line, or supply side of the horn. The relay made the horn more energetic, and the fact that the horn button on the steering wheel was only switching the small relay coil made it a little safer...but it's fine the way you intend on doing it. It was done in millions of cars for many years that way. You are correct, if you double the voltage, you half the amperage a device will draw. Your horn is going to be on steroids on 12 volts...be prepared. Stuart | | |
