4 members (frogfarmer, Ed Atkisson, Steelonsteel, 66flea), 85 guests, and 2 robots.
Topics128,095
Posts1,056,490
Members48,444
#987681 11/21/2013 5:11 AM
I have a 1953 GMC 1/2 ton pickup. The system has been changed to 12 volt but the start is still 6 volt. The starter is a foot push type. Lately I have been having a problem with the starter grinding when I step on it. I removed the starter, the gears seem to be fine but I noticed when you push the drive gear out by hand it does not twist like other starters. My question is, does the bendix drive on this type of starter supposed to twist as it moves toward the flywheel.
I have a 6v starter laying around I will check it out and get back to you later today
1963 Chevy C30 - 292 I6 +.040" 10.78:1, SM465
1978 GMC K2500
"Four gears with a granny low and six cylinders straight in a row."
May be some wear in the fork/linkage that lets the button make contact before the gear is fully engaged.
No the gear fully extends. I believe the gear is hitting the flywheel without actually engaging because the drive comes straight out without twisting into the flywheel.
The Bendix splines are straight on the 6 volt starters.
The most common cause of your problem is wear on the teeth front point. I commonly resharpen the teeth.
You can see in THIS PICTURE how they are sharpened from the factory and how they wear.
My Blog
Thank you guys, I appreciate all the help
I just replaced the starter drive in my '38 TD, and no, it doesn't 'twist' in.
Tom
Thank you
When My starter was acting up I went to ...NAPA... auto.
They had a refurbished starter on the self for about 80 bucks.
thank you
I took a look at the 6v starter I have, it does not twist while the solenoid kicks it out. Spend some time with a file and reshape the end of the gear
1978 GMC K2500
