9 members (Slick Willy, Lostbuthaulinass, Uncles51, Hotrod Lincoln, homer52, fonz8261, greenie-reddy, Otto Skorzeny, 1 invisible), 144 guests, and 3 robots.
Topics128,134
Posts1,056,410
Members48,441
#987406 11/20/2013 1:38 AM
So I began removing the hood on my '59 Apache this morning. I've never done this before but I had a shop manual and just winged it from there. Now as you'll see from my pictures that I do not a finished truck/paint job. So this process may differ for your application. I have a limited supply of tools so I just worked with what I had. And I was solo.
So here is a step by step:
1. Support hood with 2X4 and place carpet on cowling
2. Grab the handle of my floor jack
3. Place the open end of the handle on the hooked end of the spring
4. Give it a push and the spring should pop right off.
5. Grab a scribe
6. Trace around your hood hinge mounting plate
7. Check your hood support one more time
8. Remove upper hinge bolts
9. Place protector on fenders and lower hood down
10. Slide hood off front of truck slowly.
Removing Hood on '59 Apache
So I forgot to take a picture of the cardboard on the fenders. I used them as sliders to slide the hood off the front of the truck. Also that fancy hood spring tool that I used can be used to place the springs back on as well. I already tried it. Plus the handle was long enough to be clear of any possible danger (I guess you can use a long metal pipe as well). Of course if you have a finished project with nice paint you might want protect the areas around the hinge just in case the jack handle slips off. So there you have it. A hood removing process for a person going solo.
"Start living your dream now no matter what the sacrifice, and everything else will fall into place."
Sir Searchalot
Sir Searchalot
That's one way. Good ideas. I put 2x4's vertical on windshield eyebrow and down into engine bay. Drill two 1/8 holes thru hinge flange and hood mount. This is a good way to put back if you use two 1/8 drill bits then tighten bolts. If you clean or paint hood your scribe is gone. I pull backwards on the opposite end of spring in your pic with a chain and hook to release spring and install spring that way also. The rest is pad the fenders and slide like you said.
Welcome Los59. I think this is in the wrong forum though. This is the welcome section where you say hola.
I'm having a hard time picturing what your saying with those 2x4's. I haven't decided whether I'm gonna clean up the hood or not yet. I like the chain idea though.
Sir Searchalot
Sir Searchalot
It's just a way to protect the windshield . Like you did. You don't want the hood to even hit carpet. It may still crack the windshield. So I stand up two 2x4's such that they don't touch the windshield. They touch the roof and the firewall edge kind of, that's all. The hood really does not slide toward the windshield usually, but it could. Your way is good because it worked. thumbs_up The chain idea works better on 58-59 springs.
Oh ok I gotcha.
Hi Carlos,
You're doing a great job!
One thing that makes the project exciting is thinking things through and problem solving.
Doing large feats alone are certainly proud moments!
Good for you and thanks for sharing your experience.
...ummm... I was fortunate enough to have my beautiful wife assist me in removing the hood. LOL
