2 members (1955 1 Series, Peggy M), 115 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#98772 01/02/2007 6:29 AM
Anybody have a 41 wiring diagram they can post? I saw a 39 version in the tech tips section, but it sure does seem simplified and not sure if it's the same. I'm going to try to build a loom. I have wiring experience so not scared. My harness is a bit deteriorated to work from and, when its off, without fancy labeling, everything looks the same without the color coding. Thanks in advance, as always.
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
#98773 01/02/2007 6:43 AM
Here is the "Old Chevy Manual Project" listing of wiring diagrams:
http://chevy.tocmp.com/chevywiring/index.htm
There's no 1941 version, but there is a 42-48, which should be very close. The starter has that goofy polarity switch on it, which would put it in the right ballpark.
Good luck!
#98774 01/02/2007 8:49 AM
Ah Hah, that will do it. Between what is left of mine currently and this diagram, I'm ready, Thanks a bunch for the help.
1947 Chevy COE
#98775 01/02/2007 3:25 PM
Found a electrical diagram from the 1941 shop manual at the Keith Hardy site, just in case you want to compare it with the others.
http://chevy.tocmp.com/1941shop/41csm283.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#98776 01/02/2007 7:41 PM
Randy, Thanks. I will compare
Thank you both very much!
Tom
1947 Chevy COE
