7 members (crenwelge, JW51, Lostbuthaulinass, Hugh63c10, Gray_Ghost, 1955 1 Series, greenie-reddy),
161
Mod | | | Forums66 Topics128,108 Posts1,056,237 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | My 65 C60 is equipped with RH5 split rims right now. There seems to be a huge abundance of Dayton type wheels available and cheap. And I know they can be serviced by most truck tire places. What needs to be done to make Daytons work in place of the RH5's? Can it be done?
1965 Chevrolet C-60 292 Flatbed 2008 GMC Sierra SLE Z71 Crew Cab 1992 Chevrolet C1500 Cheyenne 5 Speed 2001 Harley Davidson FLHT Electra Glide Standard
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy IHBoilermaker, I would have to do some research to be sure but I think new hubs/drums would be needed to convert from Kelsey or Budd wheels to Dayton wheels. Finding a different type of Kelsey or Budd wheels possibly even tubeless wheels would be a lot cheaper in the long run, hope that helps.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | You would have to change hubs, but a lot of school buses used open center wheels. Junk school buses are a good source of 2 ton stuff with hydraulic brakes. | | |
