Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Woogeroo, Tronman, Youngin' Tut 59, WarEagle1, PullG), 152 guests, and 3 robots.
Topics128,288
Posts1,058,579
Members48,492
I have a 49 1/2, and removed my original 216 for a 235 that came out of a 61 impala. Dropped it in my pick-up and couldn't get it to start, found 4 stuck valves. I am now soaking it in penetrating oil but dont feel good about it. My question is, can I remove the heads off of my 216 and put them on the 235? Also, will I need to have the 216 heads rerworked? Wasn't having any problems with the 216 starting and running but I did have a smoking problem with it. Also could someone give me a ball park figure of what I can expect to pay for the work? Sure would appreciate any advice you guys could give me. Thanks so much.
1 Offline
The 216 head is going to have a 15 head bolt configuration, while the later 235 engine with have an 18 bolt configuration and will not be interchangeable.
We cannot solve our problems today using the same thinking we used when we created them!
Albert Einstein
Sounds like you have a 235 that has set a long time. I would check the cylinders for a ridge at the top indicating a need for a complete rebuild. If the cylinders are OK, than maybe having the head rebuilt will be sufficient to get it going again. Price for head rebuild will be somewhere between $200-$450 depending on what it needs. Complete engine rebuild is between $2000-$3000.
Well 200-450 is cheaper than a full rebuild. Thanks for the info.
