2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 7 New Guy | | New Guy Joined: Nov 2013 Posts: 7 | i am a new member long time viewer though so bear with me a little but i am having the notorious rear brake woes on this truck. i have seen that some people are converting the front to the newer bendix off a 53 gmc you just need the backing plates and enlarge the holes. Does that also work for the rear? if so where is the best place to get backing plates i havent found any. I wouldnt mind using the original huck brake system but i of course cant find any drums. i dont plan on driving it a whole lot and wont be in the city i am doing the dual master conversion as well. any help would be much appreciated i just want to drive this sexy beast | | | | | Joined: Mar 2000 Posts: 1,184 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,184 | As you have found, you can't find Huck brake drums easily. Here's a tech tip that explains what to do: http://www.stovebolt.com/techtips/adbrakes.htmAlthough not exactly applicable, there might be a tip or two in here you could adapt to your situation: http://www.stovebolt.com/techtips/55rear.htmThe other option is to go to open drive line which then opens up a world of possibilities. I have an '83 Firebird disk brake setup with a 3.73 limited slip rear. | | | | | Joined: Nov 2013 Posts: 7 New Guy | | New Guy Joined: Nov 2013 Posts: 7 | Thanks for quick response looks like a 55 axle assm. Would be great idea now I just need to find a cheap one. I do have a 1990 firebird v6 open rear parts car but if it works it would be free my favorite price. I think mine has coil springs did you have to weld on perches? Is it a good width? | | | | | Joined: Sep 2013 Posts: 36 New Guy | | New Guy Joined: Sep 2013 Posts: 36 | I was in the same position only a few weeks ago. I posted a wanted on here and I had 3 or 4 people PM me with offers of drums, for not a lot of cash. All on your side of the pond. | | | | | Joined: Nov 2013 Posts: 7 New Guy | | New Guy Joined: Nov 2013 Posts: 7 | So I found a frame on here for a 51 Chevy 3600 damaged but the brakes and axles are suppose to be good have a long haul to get it though I am pretty sure the frames and axles are the same but before I do this journey I would like someone to verify that is is in fact the same parts.... thanks Alex | | |
