1 members (Ponchogl),
108
Mod | | | Forums66 Topics128,281 Posts1,058,466 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | Wondering if my trailer is wide enough to carry a 51 big bolt. Need an idea what the outside to outside width on the front is. | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy txturbo, my truck salesmens data book lists the front tread as 58 3/4" ( center of tread to center of tread), across the fenders is 74 7/8", I would add 8" to the front tread width to come up with an overall front tire width, hope that helps. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Front is actually pretty narrow, it's the rears that likely won't fit between your trailer fenders. If you need to you can remove the outside rear wheels | | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | Yeah it's only the fronts I'm worried about....those are the only ones that need to fit between the fenders. | | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | Hy txturbo, my truck salesmens data book lists the front tread as 58 3/4" ( center of tread to center of tread), across the fenders is 74 7/8", I would add 8" to the front tread width to come up with an overall front tire width, hope that helps. that does help....thanks | | |
