Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Ponchogl), 108 guests, and 2 robots.
Topics128,281
Posts1,058,466
Members48,490
#987007 11/18/2013 4:10 PM
Wondering if my trailer is wide enough to carry a 51 big bolt. Need an idea what the outside to outside width on the front is.
3B Offline
Hy txturbo, my truck salesmens data book lists the front tread as 58 3/4" ( center of tread to center of tread), across the fenders is 74 7/8", I would add 8" to the front tread width to come up with an overall front tire width, hope that helps.
Front is actually pretty narrow, it's the rears that likely won't fit between your trailer fenders. If you need to you can remove the outside rear wheels
•1952 Chevrolet 3800 pickup
---All pictures---
Yeah it's only the fronts I'm worried about....those are the only ones that need to fit between the fenders.
that does help....thanks
