| | | Forums66 Topics128,149 Posts1,056,814 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 20 | Does anyone know the size, threads etc of the bolts used to mount gear box to frame? I am looking for the one that is installed from below frame up into gear box and the one on the other end that goes thru mounting bracket and then down thru frame.
The assembly manual shows them as part numbers 106340 and 100053, respectively. I do not see either in the parts guide but maybe i had a breakdown in my navigation skills.
Any help with bolts or navigating thru guides is appreciated. Thanks
1954 3600
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | They are 1/2" NC I don't have the lengths handy sorry. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've found 1/2" -20 which is fine thread for the bolts and nuts holding it to the frame. That's on several original AD trucks. Forget if the one tapped in the box is coarse or fine, easy enough to look though.
Grigg | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I've found 1/2" -20 which is fine thread for the bolts and nuts holding it to the frame. That's on several AD trucks. Forget if the one tapped in the box is coarse or fine, easy enough to look though.
Grigg I concur. But, I believe there are 2 each 1/2-20x1.5", 1 each 1/2-20x1.75" (all three with 1/2-20 nuts) and one 1/2-13x1". But, I see no reason not to go with all 1/2-13 (if worried about bolts loosening, then a little blue thread cement should do the trick).
| | | | | Joined: Sep 2012 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 20 | | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I think everyone who has done their research agrees that fine thread is stronger than coarse thread in general. For anything that is mechanical on the truck I make sure to use fine thread and grade 5. Don't forget that your local hardware store may sell grade 5 fine thread bolts, but generally do NOT sell grade 5 nuts. This makes your strength grade 2 in combination. Not good. I purchase nuts from McMaster-Carr (fine thread in just a few sizes) so I have what I need for the local purchase bolts.
These days I use stainless on my projects so have to be really careful to get hardened stainless equiv to grade 5 or grade 8 in certain places on the truck. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Home Depot surprisingly had a great selection of grade 8 bolts. I've been replacing my 50 year old bolts little by little.
