9 members (Wayne67vert, TooMany2count, Nick in Manitou, NJC, Mike in Sycamore, Bill Hanlon, Ponchogl, sron48, rfs56trk), 85 guests, and 4 robots.
Topics128,137
Posts1,056,747
Members48,454
Does anyone know the size, threads etc of the bolts used to mount gear box to frame? I am looking for the one that is installed from below frame up into gear box and the one on the other end that goes thru mounting bracket and then down thru frame.
The assembly manual shows them as part numbers 106340 and 100053, respectively. I do not see either in the parts guide but maybe i had a breakdown in my navigation skills.
Any help with bolts or navigating thru guides is appreciated. Thanks
1954 3600
They are 1/2" NC I don't have the lengths handy sorry.
I've found 1/2" -20 which is fine thread for the bolts and nuts holding it to the frame. That's on several original AD trucks. Forget if the one tapped in the box is coarse or fine, easy enough to look though.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Originally Posted by Grigg
I've found 1/2" -20 which is fine thread for the bolts and nuts holding it to the frame. That's on several AD trucks. Forget if the one tapped in the box is coarse or fine, easy enough to look though.
Grigg
I concur. But, I believe there are 2 each 1/2-20x1.5", 1 each 1/2-20x1.75" (all three with 1/2-20 nuts) and one 1/2-13x1". But, I see no reason not to go with all 1/2-13 (if worried about bolts loosening, then a little blue thread cement should do the trick).
Great thank you all
Gas Pumper
Gas Pumper
I think everyone who has done their research agrees that fine thread is stronger than coarse thread in general. For anything that is mechanical on the truck I make sure to use fine thread and grade 5. Don't forget that your local hardware store may sell grade 5 fine thread bolts, but generally do NOT sell grade 5 nuts. This makes your strength grade 2 in combination. Not good. I purchase nuts from McMaster-Carr (fine thread in just a few sizes) so I have what I need for the local purchase bolts.
These days I use stainless on my projects so have to be really careful to get hardened stainless equiv to grade 5 or grade 8 in certain places on the truck.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Home Depot surprisingly had a great selection of grade 8 bolts. I've been replacing my 50 year old bolts little by little.
