| | | Forums66 Topics128,060 Posts1,055,832 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | I have a 1955 chevy car transmission with B/w overdrive in my 53 3100. The tailshaft seal is leaking and i need to know what seal to use to fix the problem. And should i replace the bushing also. Thanks. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Just a normal rear seal, the one for the overdrive is no different.If you want to change the bushing, you will have to take the tailshaft housing off of the transmission. Put the driveshaft yoke back in and see if there is a lot of movement, if so maybe change the bushing.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | That seal was used on just about every transmission Chevrolet made, including most automatics.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | thanks guys. i'll get one. | | |
