8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL), 100 guests, and 2 robots.
Topics128,070
Posts1,055,892
Members48,428
#9861 08/18/2002 6:20 PM
Its time to rebuild the engine in my 50 truck. The engine is a 54 235, it still runs good but the oil pressure is getting low and a blue snake is coming out the tail pipe when I step on the gas.I see some Stovebolters run engines with shims.But remember back, there was a discussion(heated),saying shimmmed engines are "junk".The machine shop tells me shimmed 235 engines are not a problem, he used to do a lot of them.What do you say?
Porky Pig is just a ham.
#9862 08/19/2002 3:01 AM
Anonymous
Unregistered
Anonymous
Unregistered
Your 54 235 is a " Cast Iron Wonder ". Everyone wonders why they run so long. Build that motor right & you wont have to worry 'bout it again !! [ in your lifetime anyway ] .
#9863 08/19/2002 3:03 AM
Shimmed mains work fine, if they are properly done. However, a good machinist can grind the crank to match a set of bearings. It takes a little more work, since the bearings must be set in place, miked, then the crank ground. Must crank grinders simply grind to specs in a manual.
Fred
52 3600
69 C-10
