1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#986099 11/13/2013 11:09 PM
I am either sand blasting or sanding down to clean metal the parts of my '47 pickup before painting. I will be using 2K epoxy primer. The clean metal is getting some light surface rust and/or finger prints. What should I use to clean off the light rust before painting?
Thanks to all,
CAB
I'd give it a wash with phosphoric acid - and make sure you use a grease & wax remover before the primer .... and in future wear cotton gloves when handling bare metal wink
...as long as the epoxy is compatible with phosphoric acid type rust conversion treatments. Check with your paint manufacturer before jumping in headfirst with the phosphoric acid.
I believe most any Epoxy primer can be used over a Phosphoric acid prep... AFTER Proper Neutralization of the acid. That DOES NOT mean squirting baking soda over it or letting it dry over night and then painting over it.
As mentioned above, check with your manufacturer as to their procedure, some brands won't matter and some will.
Give me ambiguity
or give me something else
