0 members (),
128
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 29 New Guy | | New Guy Joined: Aug 2000 Posts: 29 | I am either sand blasting or sanding down to clean metal the parts of my '47 pickup before painting. I will be using 2K epoxy primer. The clean metal is getting some light surface rust and/or finger prints. What should I use to clean off the light rust before painting?
Thanks to all,
CAB | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd give it a wash with phosphoric acid - and make sure you use a grease & wax remover before the primer .... and in future wear cotton gloves when handling bare metal  Bill | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | ...as long as the epoxy is compatible with phosphoric acid type rust conversion treatments. Check with your paint manufacturer before jumping in headfirst with the phosphoric acid. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I believe most any Epoxy primer can be used over a Phosphoric acid prep... AFTER Proper Neutralization of the acid. That DOES NOT mean squirting baking soda over it or letting it dry over night and then painting over it.
As mentioned above, check with your manufacturer as to their procedure, some brands won't matter and some will.
