6 members (Otto Skorzeny, greenie-reddy, mick53, dt235sd, DadsFirstPickup, 5 Window 9434), 72 guests, and 1 robot.
Topics128,157
Posts1,056,874
Members48,456
Hi Guys I've got a 53 1/2 ton I bought out of California a couple of months back. The truck has a 350 under the hood and the rad is a triple core with dual electric fans (fore & aft). The PO has wired in the electric fans hot to the ignition switch so they run continusly while the truck is on. I was thinking I should get a radiator shop to sweat in a fitting for a thermo-switch to control the fans coming on and off seeing as I live in Canada and I don't need continuose cooling and it would probably be best to bring the engine up to operating temp. I just wanted to know if any other members had any thoughts on this.
I
Junior Member
Junior Member
I Offline
You should be able to thread a switch into a water jacket of the engine
Some thermal switches just mount to the cooling fins of the radiator, so you don't need any special fittings. You want the switch downstream from the themostat, otherwise it cycles too fast.
How about hooking up one to a thermal switch-maybe in the port in the manifold-and put the other on a manual switch? Then you can use one as a primary cooling fan and only use the other when you really need it.
Bill Burmeister
look around I think you can get sw that fastens to rad core without much problem to run fans..doc
I have a thermal switch on mine. Has a probe that just slides thru the radiator fins - no cutting or soldering req'd. Has an adjustable knob for on/off temps.
1940 Chevy KC 1/2-Ton
there you go problem solved..doc
