1 members (klhansen),
147
0
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#98577 12/23/2006 12:42 AM | Joined: Sep 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 42 | Hi Guys I've got a 53 1/2 ton I bought out of California a couple of months back. The truck has a 350 under the hood and the rad is a triple core with dual electric fans (fore & aft). The PO has wired in the electric fans hot to the ignition switch so they run continusly while the truck is on. I was thinking I should get a radiator shop to sweat in a fitting for a thermo-switch to control the fans coming on and off seeing as I live in Canada and I don't need continuose cooling and it would probably be best to bring the engine up to operating temp. I just wanted to know if any other members had any thoughts on this. Thanks | | |
#98578 12/23/2006 1:00 AM | Joined: Jan 2004 Posts: 10 Junior Member | | Junior Member Joined: Jan 2004 Posts: 10 | You should be able to thread a switch into a water jacket of the engine | | |
#98579 12/23/2006 2:38 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Some thermal switches just mount to the cooling fins of the radiator, so you don't need any special fittings. You want the switch downstream from the themostat, otherwise it cycles too fast. | | |
#98580 12/23/2006 3:38 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | How about hooking up one to a thermal switch-maybe in the port in the manifold-and put the other on a manual switch? Then you can use one as a primary cooling fan and only use the other when you really need it.
Bill Burmeister | | |
#98581 12/27/2006 5:48 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | look around I think you can get sw that fastens to rad core without much problem to run fans..doc | | |
#98582 12/27/2006 5:56 PM | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I have a thermal switch on mine. Has a probe that just slides thru the radiator fins - no cutting or soldering req'd. Has an adjustable knob for on/off temps. | | |
#98583 12/28/2006 4:01 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | there you go problem solved..doc | | |
