| | | Forums66 Topics128,081 Posts1,055,959 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 32 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 32 | Block number "3769716" and date number is " G 6 1 "[ July 6, 1961 ] and stamp next to distributor is "F0707J" and no other digits. F is for Flint but what is the "0707J'" all about? Would this have been a new engine from a Chev or other GM dealer directly from Chevrolet? Bill
Bill garvey
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | F 0707 J (this code pattern was used from 57-63)
F= Flint, MI plant
07 = July 07 = 7th
J = 3100-3200-3800 1958-63(?) trucks with regular production engine/transmission
J - 3400-3500-3700 1957 trucks | | | | | Joined: Apr 2005 Posts: 32 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 32 | Thanks, with the date casting on the block, [G-6-1] it must be out of a '61 or '62 3100, 3200, or 3800 truck, correct?
Bill garvey
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bill,
I guess the same as you. It could be 1961, but that would be one day after casting (I think - I might be decoding incorrectly).
| | | | | Joined: Apr 2005 Posts: 32 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 32 | The other puzzler is the lack of other numbers in normal serial numbers preceeding these 6 digits. Its not a big deal, just curious. Thanks.
Bill garvey
