2 members (Peggy M, MickeyP),
122
Mod | | | Forums66 Topics128,088 Posts1,056,408 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 28 New Guy | | New Guy Joined: Aug 2002 Posts: 28 | Ok, the coolant is coming from a small hole that is just below the intake port. All 3 intake ports have this hole, but only the center one is leaking. I thought it was a head gasket and decided to take it off. As soon as I remove the manifold the coolant started coming out stronger. This hole is covered by the intake gasket. Any thoughts on what this is? Cooling jacket leak?
"If you're not living on the edge, you're taking up too much space. Life is short, eat desert first."
| | | | | Joined: Aug 2002 Posts: 28 New Guy | | New Guy Joined: Aug 2002 Posts: 28 | After much thought, can this be for the heat box for the manifold/carbureator? If so, I don't have one on this setup so it is just a question of plugging the hole with some sealant and tightening the gasket and manifold flange tight.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It might help if we knew what engine you are working on. There should be no holes into the cooling system to the intake on a '50s era Chevy six. Is this a V8? | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Not sure which engine you have. However the stock intake on a 216,235,and a 261 are all heated by the exhaust manifold. No water in the stock intake. Lots of after market 2 and 3 barrel intakes use water to heat. If it is a threaded hole then use a sealer and a set screw to seal it. If it not threaded find out what it is before you put a "goober" fix on it. You will not like the results. Trust me. The intake/exhaust gasket is only under compression at the ports and does distort in between them. So it won't help you with sealing anywhere that is not a port. If the hole is easy to get to you can run a tap in it a little ways and then put in a set screw. That might work just fine.
Steve H
| | | | | Joined: Aug 2002 Posts: 28 New Guy | | New Guy Joined: Aug 2002 Posts: 28 | It is a 1954-235 engine. It is very small pre-drilled hole that exists beneath all 3 intake ports. It is not threaded. A 1/8" drill bit shaft fits into the holes. It originally appeared to be a leak at the head gasket until I took off the manifold enroute to removing the head. At this point, coolant flowed out of the hole. It is a Clifford manifold with a 6:8 stamped on it. Head casting #3835913-Engine Block # F54Z I ask about the water heated manifold only because I am aware it has been used in the past but it does not exist on this engine. As soon as I can figure out how to post a picture I will.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I have that head, no holes that you describe ...pic... | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Aug 2002 Posts: 28 New Guy | | New Guy Joined: Aug 2002 Posts: 28 | My Pics http://www.flickr.com/photos/108402734@N07/with/10811005153/
| | | | | Joined: Aug 2002 Posts: 28 New Guy | | New Guy Joined: Aug 2002 Posts: 28 | DADS50, If it is on your head, the holes will be underneath your ports but beneath the gaskets.
| | | | | Joined: Aug 2002 Posts: 28 New Guy | | New Guy Joined: Aug 2002 Posts: 28 | http://www.flickr.com/photos/108402734@N07/with/10811005153/ www.flickr.com/photos/108402734@N07/with/10811005153
