1 members (dunfire),
157
Mod | | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 5 New Guy | | New Guy Joined: Feb 2010 Posts: 5 | Can anyone tell me if the ohm resistance for 1960-1966 is 0-30 for the fuel gauge. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy chopperguy16, I know they changed the sender and gauge from a 0 - 30 ohms to a 0 - 90 ohms somewhere in the 1960s. Classic Industries website lists 1964 and older as 0-30 ohms, and 1966 and newer as 0-90 ohms (I guess the 1965 vehicles didn't have fuel gauges). I did try looking in the parts book to pin down the year they changed, but with all the different models, each with their own sender I just got a headache, hope that info helps some. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Mid year 1966 they changed to 0-90 ohms
The previous models were 0-30 ohms | | | | | Joined: Feb 2010 Posts: 5 New Guy | | New Guy Joined: Feb 2010 Posts: 5 | | | | | | Joined: Feb 2010 Posts: 5 New Guy | | New Guy Joined: Feb 2010 Posts: 5 | THANKS FOR THE INFO HOT ROD | | | | | Joined: Dec 2009 Posts: 4 'Bolter | | 'Bolter Joined: Dec 2009 Posts: 4 | Hi y'all. After finding bad fuel full of sediment downstream of the fuel pump on a '66/292 that I have owned for 15 years, I yanked the tank and found a very small leak in one of the corners, and a corroded sending unit. The gage has never worked. My mechanic tells me he could etch and seal the inside. The chemicals for this are $120 but he has chemicals from another tank. I found a replacement tank at Classic Industries for $150. I am wondering if anyone has experience with sealing the inside. I did a similar operation on a hypolon inflatable raft years ago and thought it worked well. Also, is the a visible difference between the 30 and 90 ohms sending unit. The replacement sending unit on websites is described as the 0-30 ohms. Thanks for the help. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If a replacement tank is only $150, that is by far better. you will "mess" around with that tank, they will mess around with it and you will never know if all leaks are fixed and if they just coated over some rust/varnish. Subtract what they will charge from $150, that's your decision number. Three different vendor websites indicate 30 Ohm up thru 66. One site says ...."and some 67". If you buy one for a 1966 and it does not work, they will take it back because you did nothing wrong as long as gauge is original or equiv.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2009 Posts: 4 'Bolter | | 'Bolter Joined: Dec 2009 Posts: 4 | Thanks for the help. Once I put the tank in my basket, it went from available to out of stock. I'll get the 30 ohm sending unit and look for a tank thru the weekend. If I don't find one, I will give the chemicals a try. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | There are other vendors who do have the tanks at that price. Like Classic Parts of America, a sponsor here. Shipping is about $50.
