Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (55shaker, Shade Baby, Bill Hanlon, Jon G, 78buckshot, TrknGMC, 1 invisible), 109 guests, and 3 robots.
Topics128,274
Posts1,058,436
Members48,490
I just recently rebuilt my caburetor (216) one barrel...put everything back together...hooked up the throttle cable and choke....forgot where the spring connects to....I see the hole on the gas pedal lever where does the other end connect to?
1951 3100
http://community.webshots.com/user/HolcombRacing11
"Every child is an artist. The problem is how to remain an artist once he grows up."
Pablo Picasso
here is an answer from a previous post
The throttle cable replaces the little cotter pin that is on there now holding the rod onto the carb. You need the little clamp at the end of the throttle cable to keep it in place.
check out this one and look at cletis's pix, maybe that will help
click here
Redryder pix
My Hotrod
thankyou for that picture...I have that piece with the throttle cable going through the area that is described...but I'm missing a spring I think...on the lever that meets up with the carb...as if now you step on the pedal and it stays on the floor...I have no return....so I think there is a spring attached somewhere. On the arm leading up to the carb....I have a bracket attached on the long shaft....it looks like a spring attaches there and then attaches down by the motor somewhere...
1951 3100
Pablo Picasso
It hooks to the tab on the throttle linkage below the intake. I'm not sure where mine originally attached down below, it was wired to the exhaust pipe! So I fabricated a tab that bolts up under an oil pan bolt and ran the spring down to that.
Thank you I wasn't sure if I explain right the first time...so I tried posting again..thank you very much...I started thinking maybe I rebuilt the carburetor wrong...but that makes great sense..thankyou again
1951 3100
Pablo Picasso
No prob- Good luck.
