2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#98478 12/17/2006 12:00 AM | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | I just recently rebuilt my caburetor (216) one barrel...put everything back together...hooked up the throttle cable and choke....forgot where the spring connects to....I see the hole on the gas pedal lever where does the other end connect to? | | |
#98479 12/17/2006 12:38 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | here is an answer from a previous post The throttle cable replaces the little cotter pin that is on there now holding the rod onto the carb. You need the little clamp at the end of the throttle cable to keep it in place. check out this one and look at cletis's pix, maybe that will help click here Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#98480 12/17/2006 1:18 AM | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | thankyou for that picture...I have that piece with the throttle cable going through the area that is described...but I'm missing a spring I think...on the lever that meets up with the carb...as if now you step on the pedal and it stays on the floor...I have no return....so I think there is a spring attached somewhere. On the arm leading up to the carb....I have a bracket attached on the long shaft....it looks like a spring attaches there and then attaches down by the motor somewhere... | | |
#98481 12/17/2006 6:01 AM | Joined: Nov 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 96 | It hooks to the tab on the throttle linkage below the intake. I'm not sure where mine originally attached down below, it was wired to the exhaust pipe! So I fabricated a tab that bolts up under an oil pan bolt and ran the spring down to that. | | |
#98482 12/17/2006 6:07 AM | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | Thank you I wasn't sure if I explain right the first time...so I tried posting again..thank you very much...I started thinking maybe I rebuilt the carburetor wrong...but that makes great sense..thankyou again | | |
#98483 12/17/2006 6:29 AM | Joined: Nov 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 96 | | | |
