| | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 22 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 22 | I bought a nice 50 half ton on ebay. I got it Tuesday today after work I crawled under it to look at the floor pans for mounting seat belts. And I see it does not have the stock rear end. It has the cast number on the front 1253741 and then 7 6 03. | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy Pastlite, a picture would help me more than the numbers would. Is it an open drive rear axle? The second group of numbers might be a casting date, July third 1953, or maybe 1963, hope that helps. | | | | | Joined: Apr 2011 Posts: 22 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 22 | Thanks 3B its a open rear axle so its not a 53. Its a lot higher geared. The truck is a 4 speed that use to be 3 speed. Unlike the 2 4 speed trucks I use to own. 53 half ton and 47 one ton this one is so high geared you can use first gear.
When setting goals in life. Always aim low to avoid disappointment
