3 members (Hotrod Lincoln, Bill Hanlon, mick53), 123 guests, and 1 robot.
Topics128,109
Posts1,056,262
Members48,439
#984364 11/07/2013 7:08 PM
My aftermarket replacement bed sides didn't come with fender holes drilled, anyone have any tips? I attached the running board and splash apron so that should locate the fender in the front. For the rear, I believe the second hole from the bottom should go through the bed's angle strip?
Also, is the splash apron supposed to have about a 1" gap (I'll get a picture later) to the bottom of the bed side?
'53 Chevy truck 1/2 ton
Try Mar-K they sell bed sides. Give them a call.
http://www.mar-k.com
Denny G
Sandwich, IL
My gap is about 1/4 inch; the thickness of the rubber pad that belongs under the wood block that supports the bed floor.
Which raises another question. Did the trucks actually have a
rubber pad under the blocks from the factory or is that just
an invention of a creative vendor who thought it might be a
good idea???
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
That is a good question Denny. When I removed my '50 bed it had a very heavy webbing (deteriorated some) so maybe the rubber came later. I may have seen the webbing on a pic of it from DADS50 maybe?
Drew
I agree. They came with a heavy canvas woven pad probably 3/32 to 1/16in. I still have mine. I can take a photo if you want.
I would like to see the pictures of your woven pads for my own reference please post when you can.
How bout you Brad, you've probably seen more original truck beds
off the frame than anyone here on the forum. What have you seen
during all of your salvage operations??
Denny G
Denny G
Sandwich, IL
Denny most of the trucks I have bought were either big boys, cabs, or had the bed off the truck. I have seen bits and pieces but never enough for me to do a study on them. The complete trucks that I bought for resale I never really looked close enough, I will from now on.
I'd take them back if they don' have holes. Go with the Mar k, like the other fellow posted.
There uploaded on my photobucket. I suspect they were vulcanized material like tires. I suspect they were about 1/4 inch thick when new. They are a little over 1/8 now.
