2 members (Bill Hanlon, Otto Skorzeny), 111 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#984597 11/08/2013 7:40 PM
I dropped the tranny on my 57 2-Ton in order to remove the pressure plate and clutch disc. However, the transmission support bridge does not allow for an easy removal. Do I have to lift the engine in order to move it forward to get the pressure plate and clutch disc out? Or is there a trick to getting these out without lifting the engine?
Glory Bound...
Raul T. #984620 11/08/2013 10:00 PM
Riding in the Passing Lane
Usually if you push the disc up into the upper part of the bell housing you can drop the pressure plate out first.
1972 Chevy c10 Cheyenne Super
Raul T. #984621 11/08/2013 10:01 PM
Well beings as the engine is supported from the front and the sides of the bell housing yes you will need to support the rear of the engine to remove the bell housig.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Raul T. #984622 11/08/2013 10:08 PM
3B Offline
Hy rautru, you should be able to get the pressure plate and clutch disc out the bottom of the bellhousing without removing the engines rear mounts. Once the inspection cover is removed from the bottom of the bellhousing there should be enough room to unbolt the pressure plate and lower it out the bottom of the bellhousing, hope that helps.
Raul T. #984635 11/08/2013 11:27 PM
I shall try pushing the disc upwards and seeing if the pressure plate drops. Thanks for the feedback guys.
Glory Bound...
Raul T. #984929 11/10/2013 12:46 AM
removing the pivot ball and holding the pressure plate upward with a wire did the trick. Thanks for the input guys.
Glory Bound...
