8 members (rfs56trk, Frank50, BarryP, Gazz, UtahYork, Jon G, Ole49GMC, 1 invisible),
106
Mod | | | Forums66 Topics128,134 Posts1,056,740 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | I was working on the brakes in my 41' Chevy half ton, and happen to have a 2006 F150 6 lug rim sitting near by. Guess what? Yep, a perfect bolt pattern /center match! For whatever that is worth? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I think you'll find that the lug pattern on the Ford wheel is actually slightly smaller than the Chevrolet. The Ford pattern is 6 x 135mm, the Chevrolet is 6 x 139.7mm. That will prevent the lug nuts from properly seating. In addition, the backspace and offset are not correct.
Bill Burmeister | | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | Thank you. The good news is that I can buy nice looking alloy wheels without a major hunt. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Don't sound like much till you see it illustrated: http://www.pbase.com/dennygraham/image/153279066Thanks for pointing that out Bill, might have avoided a serious accident. DG
Denny G Sandwich, IL
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Yes, the good news is any 6 on 5.5" (6 on 139.7) bolt pattern wheel will fit. This is every 6 bolt GM truck wheel up to current, and Nissan Titan, etc. Where you might run into issues is with the backspacing on the newer wheels, as your '41 was mean to run very narrow wheels, you might run into clearance issues. As with anything else, measure, measure, measure. | | |
