9 members (Gdads51, 52Carl, fonz8261, greenie-reddy, 2-Ton, Forty9, RoadsScholar, mk72, 1 invisible), 138 guests, and 1 robot.
Topics128,125
Posts1,056,343
Members48,441
#984349 11/07/2013 6:00 PM
54 3100
I just put new tires on my truck. I'm installing a mono leaf spring set next week that drops the rear 5" but I noticed the tires seem to stick out past the rear fender. Does anyone have experience with this or a solution?
http://imgur.com/WlCUnAP
http://imgur.com/tNZogki
My tire size is 265/60R15
DJ __|__
--O-(_)-O--
'54 Chevy 3100
http://imgur.com/5XR6yO3
Wider fenders?
www.streetrodhq.com
Item # 3682835W
Wheels with less backspacing?
regards,
Leon
Wheels or I put a jack handle on the tire and rolled the fender for a slight flare. It's hillbilly but it worked and didn't crease. I have a 6" drop and 18" wheels on a 65 c10 long bed. Good luck to ya.
I'm not sure if there is any back spacing to remove.
DJ __|__
--O-(_)-O--
'54 Chevy 3100
Back spacing on the wheels. I run 18x10 with 5.5 back spacing. Like reverse deep dish wheels. It's an offset. You may need different wheels.
If there isn't any room for wheels with more backspacing, you might need to go to a 1" narrower wheel. Since I really don't like the look of widened fenders I would be looking for wheels that fit within the fenders, or get custom ones made. What wheels are on the truck?
My 46 GMC on Photobucket
