0 members (), 108 guests, and 2 robots.
Topics128,035
Posts1,055,560
#984340 11/07/2013 4:52 PM
Does anyone have photos of what the firewall should look like on a '42 1/2 ton. I know I have more holes than I need but would like to use the correct ones. I'm trying to find a picture showing what goes through or is bolted to what hole.
gerrys42 #984425 11/08/2013 1:50 AM
On page 7 of my photo bucket you can see the cab of a 46. I believe they are the same as the 42. On the drivers side there are 4 holes not stock that hold my oil filter. The rest are stock.
gerrys42 #985079 11/10/2013 2:56 PM
Gerry,
I went through the same exercise a while back good luck as time makes many holes! Look at the link below. My image is from a 2/41 military which was transitional between true military specifications and civilian so most of the holes are the same for civilian models. The voltage regulator is different, and perhaps the main wiring harness hole on your 42 is located lower on the firewall (on GI's the harness location changed somewhere late 1942). Hope this helps.
Paul
http://g503.com/forums/viewtopic.php?f=25&t=215388
Lots more pictures
Paul_WNC #985404 11/11/2013 5:18 PM
Thanks for the help guys!
gerrys42 #985841 11/12/2013 11:24 PM
GWWirth Your truck is looking good
Looks like your making good progress too.
