2 members (baldeagle, 1 invisible), 90 guests, and 3 robots.
Topics128,018
Posts1,055,340
Members48,419
#98416 12/13/2006 3:08 PM
Does anybody know how the spotlight works and how everything moves? I know when you twist the handle, the gears are supposed to make the actual light assembly move right to left, is this correct? All I see is one gear on the spotlight end of the assembly and I don't see how anything from inside the cab turns that gear. I turned the actual light by hand and the gear turned, but nothing else was affected. Am I missing a gear on the spotlight end? I probably need a good used one because the rivets on mine where the light housing attaches to the assembly are rusted and I can't remove the nut that is holding the light housing on either.
#98417 12/13/2006 3:17 PM
http://www.unityusa.com/
check out this site from a previos post.
There should be 2 gears on each end. I broke one due to thick grease and cold weather, my local napa store found me the gear.Now i use dielectric grease on them and all is ok now.Hope this helps,tom
