| | | Forums66 Topics128,017 Posts1,055,338 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#98416 12/13/2006 3:08 PM | Joined: Nov 2006 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 125 | Does anybody know how the spotlight works and how everything moves? I know when you twist the handle, the gears are supposed to make the actual light assembly move right to left, is this correct? All I see is one gear on the spotlight end of the assembly and I don't see how anything from inside the cab turns that gear. I turned the actual light by hand and the gear turned, but nothing else was affected. Am I missing a gear on the spotlight end? I probably need a good used one because the rivets on mine where the light housing attaches to the assembly are rusted and I can't remove the nut that is holding the light housing on either. | | |
#98417 12/13/2006 3:17 PM | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | http://www.unityusa.com/ check out this site from a previos post. There should be 2 gears on each end. I broke one due to thick grease and cold weather, my local napa store found me the gear.Now i use dielectric grease on them and all is ok now.Hope this helps,tom | | |
