8 members (Donf, Gdads51, 55shaker, FAST55, Ponchogl, Wickedbass, Cosmo, Hanks custodian),
66
Mod | | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I have the carter 2100 with manual choke on my 235. It starts and idles fine. After I have driven at 40-50 mph for a distance the engine dies when I let off the gas. Any ideas why this happens?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Does it restart, or do you have to wait a while?
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | California gasoline? Is the float set right?
| | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | Tons of possibilities:
(1) This carb is calibrated for use with a standard transmission. Are you trying to use it with an automatic?
(2) Is there a pertronix conversion in the distributor? If so, has the generator been replaced with an alternator?
(3) Have you done a compression test on the engine?
(4) Will the engine start immediately and idle?
(5) Is the coil breaking down with heat?
(6) Has the engine compartment been painted to where the battery ground to body is inadequate?
(7) Turning to the carb, are you using the flange mounting gasket supplied BY CARTER???
(8) How many turns out is the idle mixture control screw?
(9) Are you required to use E10? If so, has the carburetor idle circuit been recalibrated for the E10?
Rereading my list, number 2 is the most likely culprit!
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Jon-- why is 2 the most likely culprit? Just wondering. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Jon-- why is 2 the most likely culprit? Just wondering. Me two. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | Jon-- why is 2 the most likely culprit? Just wondering. Electronics items require a stable (constant) voltage to work well. Generators do not produce a stable voltage at idle. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Hi all. Thanks for all the responses.
Engine is a rebuilt 235. No electronic setup - points and condenser. It takes a while to restart and requires full choke. Oh, it would restart and run if truck is moving and the clutch is dumped. I also needed to set the idle higher. I think this plays along with having to close the choke.
Not sure about the coil breakdown and my ground is good.
Again, thanks
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Oh. I have an sm420 4 speed transmission.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Ooops.
I do not know about the flange mounting gasket by carter. I am using the one for a Rochester. If we are talking about the one between the carb and manifold.
| | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | Hi all. Thanks for all the responses.
Again, thanks If the idle RPM is set too low, the engine will stall when hot. I would suggest using a tachometer, and setting the engine to the specified idle RPM. See if this fixes the issue. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks Jon. Do you take calls other than Monday and Tuesday's?
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | A friend said this is a common issue with the carter carburators.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I took the carter off and replaced it with a Rochester. It started up and with a little adjustment it ran well. I shut it off and it would not restart.
Now what?
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Start at the beginning. I don't think you have a big problem with the carb. I think you have some issues with the ignition. Look for a good rubbing block on the points. Yes I have had that critter fall off. No spark and no go. If the points are OK check the point gap on the high part of the lobe. If all of this is OK then look real hard at the coil. If you are running 12 volts and have a 6 volt coil you will get the coil hot and it will break down or quit. If it survives you will burn the points with too much current. Get a new coil rated for the voltage you are running and try that. Should be able to find one that is not too expensive. Same issues with 2 carbs is trying to tell you to look elsewhere.
Steve H
| | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | To check for wire issues, hot wire the coil right off the battery bypassing the ignition key, resister wire, and wire harness. If it still dies, you now know the wires and switches are good. If it runs, back track up the wires till find a problem.
When it restarts, does it blow black smoke out the tail pipe? does it smell like raw fuel? Next time it dies, roll to the side of the road and pull the filter for a quick look down the carburetor.
Does it appear wet or dry? Does it spray fuel when you move the throttle lever?
Don't swapped more then one part at a time, if it made no difference, swap the original back on. You can get into a real mess changing parts, and sometimes never know which one fixed it.
It will be something simple, it always is, as these engines are as simple as it gets.
Joe
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Coil? I will try a new coil. Jon mentioned that earlier and now I have a second mention. Sorry, I am slow.
I am running 6 volts.
Thanks to all. I will post all findings
| | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | Thanks Jon. Do you take calls other than Monday and Tuesday's? No, I am trying to retire, but the government mandate on ethanol won't let me. I work Wed, Thurs, Fri, and Sat taking care of what transpired on Mon and Tues. If I took calls the other days I would get nothing done other than taking calls. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | A friend said this is a common issue with the carter carburators. No more so than with any other brand. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thank you Jon.
I bought a replacement 6 volt coil and plan to put it in tomorrow. I will run the truck and see what difference it makes. I also plan to run it with the carter. If I have problems with this setup I will switch carburators back to the Rochester.
I will get past this so I can move on to the next issue.
Thanks again to all for your help
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Truck runs fine with new coil and condenser. I switched out the solenoid and the starter kicks over faster, too.
Life is good. Now, on to the next issue
