5 members (kades51, 55shaker, Gray_Ghost, 2 invisible), 172 guests, and 3 robots.
Topics128,260
Posts1,058,319
Members48,485
I got a spare tm420 to use while rebuilding my original.
But the rear bearing retainer (tailpiece) was broken and removed. After removal, the mainshaft assembly seems to have shifted to the rear. I now see some roller bearings loose in the case.
Assuming these fell out of the clutch gear assembly, is there a way to sneak them back in without complete disassembly?
52 3100 project
54 3100 / 3112 ice cream truck, next project
I believe it's possible to pull the front bearing retainer and input shaft, and pack the bearing rollers into the back of the input. I don't remember if the cluster gear has to be dropped down into the case or not to allow the input to come out!
Denny G
Sandwich, IL
OK, that cutout section of the symchronizer area isn't there on some of the passenger car transmissions I've worked- - - -won't clear the cluster gear teeth without that feature!
yepper.
DG
Denny G
Sandwich, IL
Riding in the Passing Lane
The main drive shaft will come out on a 420. On a SM465 you have to drop the Cluster gear down.
1972 Chevy c10 Cheyenne Super
