| | | Forums66 Topics128,260 Posts1,058,312 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | I got a spare tm420 to use while rebuilding my original. But the rear bearing retainer (tailpiece) was broken and removed. After removal, the mainshaft assembly seems to have shifted to the rear. I now see some roller bearings loose in the case. Assuming these fell out of the clutch gear assembly, is there a way to sneak them back in without complete disassembly?
52 3100 project 54 3100 / 3112 ice cream truck, next project
| | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | is there a way to sneak them back in without complete disassembly? I believe it's possible to pull the front bearing retainer and input shaft, and pack the bearing rollers into the back of the input. I don't remember if the cluster gear has to be dropped down into the case or not to allow the input to come out! Jerry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | OK, that cutout section of the symchronizer area isn't there on some of the passenger car transmissions I've worked- - - -won't clear the cluster gear teeth without that feature! Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The main drive shaft will come out on a 420. On a SM465 you have to drop the Cluster gear down. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
