3 members (Wheelie, Ole49GMC, GMCJammer51), 98 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
This is an intake manifold.
I've tried the CASTING number thread on here and on Google and many other places with no luck.
8835682?
3835682?
3885682?
http://sdrv.ms/1hzzWod
Greg
1947 M15 Studebaker 454 4x4
1949 Chevy COE
More pix of the COE
1950 Harley FL
1958 GMC LCF 455 3x2bbl
1961 Chevy C60 Tilt Cab 327
1966 Chevy C60 Tilt Cab 496
1961 Chevy K10 sb 292
1974 Harley FXE
1979 Chevy K10 sb
2007 Harley Streetglide
I'm not that good but I'm slow
looked there. didn't find anything on MANIFOLDS
1949 Chevy COE
More pix of the COE
1950 Harley FL
1974 Harley FXE
1979 Chevy K10 sb
Did you try the GM parts Wiki? There is a link at the top of General Truck Talk.
What engine?
What make (GMC/Chevrolet)?
1955 235 chevy motor
1949 Chevy COE
More pix of the COE
1950 Harley FL
1974 Harley FXE
1979 Chevy K10 sb
the manifold is an updraft...
trying to determine if it's a 41-49 or 50-54. It will make a
difference on what carb to try to get
1949 Chevy COE
More pix of the COE
1950 Harley FL
1974 Harley FXE
1979 Chevy K10 sb
That's it. Thanks. Bad news tho... Just bought a 517
#449979 - Sun Sep 07 2008 01:16 PM Need a little casting number help
Hotrod Lincoln Online
Master Gabster Registered: Mon Feb 23 2004
Loc: Dellrose, TN
Hi, all! I've got an intake/exhaust manifold assembly that I've been told is for a Chevy COE with a 235 engine. The exhaust manifold casting number is 3835580, and the intake appears to be 3835582, but it is not very distinct. It's got a big 1-barrel updraft carburetor, and an exhaust outlet near the #6 cylinder area. Does anyone have a casting number book handy? Thanks in advance!
_________________________
Re: Need a little casting number help [Re: Hotrod Lincoln]
spanky Offline
Shop Shark Registered: Fri Dec 20 2002
Loc: burlington, n.c.
Need to make sure he has a '50-'54 COE, with Carter 871, or 2075 Carb. The Carter 517 updraft, that was used on the '41-'49 Chevy COE's, won't fit this manifold.
Spanky Hardy......Collector Of Fine Old G.M. COE Trucks & Antique Holmes Wreckers
1950 GMC 250 1-Ton in the Gallery
Top
1949 Chevy COE
More pix of the COE
1950 Harley FL
1974 Harley FXE
1979 Chevy K10 sb
Carburetion specialist
Don't know about the casting numbers, but the earlier Chevrolet updraft Carter BB carbs had a center to center spacing of 2 11/16. Most common of these would be the 517s. Later carbs would have a center to center spacing of 2 15/16. Most common of these would be the 871s.
Jon.
The Carburetor Shop
