0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
Can the glass be removed and replaced in a side vent window on a 56 chevy Truck? Any tips and tricks? Mine is cracked outward from the locking mechanism. Thanks for any help. If I need a totally new frame and glass, what is the going price from a used truck and how hard to install?
1956 Chevy 3100 Stepside Shortbox
More pix on Photobucket
yes, the glass can be replaced - easiest with the vent assembly out, and the procedure for removing the vent assembly is in the shop manual, but possible in place - the bedding compound needs to be softened to get the glass out, then cleaned out - any local glass shop should be able to do it
As always red58, a pleasure getting your help and wisdom!
Moderated by  ndkid275, Phak1
