| | | Forums66 Topics128,096 Posts1,056,482 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | Can the glass be removed and replaced in a side vent window on a 56 chevy Truck? Any tips and tricks? Mine is cracked outward from the locking mechanism. Thanks for any help. If I need a totally new frame and glass, what is the going price from a used truck and how hard to install? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, the glass can be replaced - easiest with the vent assembly out, and the procedure for removing the vent assembly is in the shop manual, but possible in place - the bedding compound needs to be softened to get the glass out, then cleaned out - any local glass shop should be able to do it
Bill | | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | As always red58, a pleasure getting your help and wisdom! | | |
