8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible), 99 guests, and 7 robots.
Topics128,264
Posts1,058,358
Members48,485
#982922 11/01/2013 4:48 AM
I have a '46 2-ton Chevy with the original 235. It usually runs well, but once in a while it will cough and when it does, it jambs the choke shut. Instead of the knob popping out from the dash, the wire in the cable will kink near the carb. I have thought of a way to hook up the cable so this won't be an issue, but I also wonder what could be causing this to happen in the first place. The carb was recently rebuilt and I have had issues with the manifolds loosening up on it. When it's not doing this, it runs really well and has a surprising amount of power. It usually happens when the engine is not yet up to full operating temperature, and maybe that's normal, but I thought it might be wise to see of there could be some other problem that needs fixing. Thanks
Ed Hotaling #982968 11/01/2013 1:18 PM
Are you saying the choke butterfly is actually pushing the cable and the knob out from the dash like you pulled it close? WOW. I've never seen a cable that lose. Are you sure its the right cable? My Jeep, GMC, and Chevvy cables are all fairly tight and I don't see how it would move unless I put a firm hand on it.
Ed Hotaling #982972 11/01/2013 1:43 PM
It couldn't be the engine mounts (rubber) getting bad. When the engine coughs the engine moves and jams the cable? I have seen choke cables that allow the choke butterfly to not fully open or close if the out housing of the choke cable isn't anchored at both ends.
Whitelightning #982980 11/01/2013 2:15 PM
Once a cable kinks and you straighten it, it takes less effort to kink it again. Each time you repeat the cycle it is easier to kink.
Ed Hotaling #982992 11/01/2013 3:26 PM
The choke cable is firmly anchored at both ends. The carb end is in the factory clamp attached to the carb housing. Before I replaced the cable, it would move the cable. Now it just bends it.
The question is Why is it doing this in the first place and is it a symptom of a problem with the engine or is the cough just normal?
Ed Hotaling #983087 11/01/2013 11:33 PM
Don't know that a "cough" on the engine is normal, but can't figure why it bends or moves the cable. Sounds like the engine pops back through the carb. maybe it is enough of a pop through the carb that it moves the choke plate.
Ed Hotaling #983096 11/02/2013 12:21 AM
A back fire thru the carb can be inlet valves too tight.
Ed Hotaling #983270 11/02/2013 9:28 PM
Thanks, Dusty. I will check on that.
Ed Hotaling #984882 11/09/2013 9:46 PM
I finally got to check the intake valves. 2 were a little tight, the rest looked OK. It still does its popping thing, but I cut an inch off thoke cable and put in a short piece of small chain so when it moves the choke plate now it doesn't bend the cable and the air flowing through the carb pulls it back open.
