1 members (78buckshot),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | Need a new headlight switch for my 54 Panel, Any place I should buy it or are they all the same in quality? Thanks.
layback
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I just bought one from the truck shop here in California. It is an original fashioned repop. I installed it and it works fine.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | His dad is the wholesale importer of a lot of the parts that we get from the vendors. Good chance that they are all imported by him, I just can't feature multiple manufacturers tooling up to make a very limited volume item like an AD head light switch.
Just had this conversation with a good buddy this week. We both feel that the vast majority of the reproduction parts are sourced from the same manufacturers.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The best would be NOS AC-Delco. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | The repop switches are fine, it's the repop knob/shaft that stinks. The knob is held onto the shaft by a set screw and, in my experience, will fall off every time you pull on it. | | |
