5 members (55shaker, 49nut, ndkid275, Gdads51, Rusty Rod), 112 guests, and 3 robots.
Topics128,130
Posts1,056,367
Members48,441
Need a new headlight switch for my 54 Panel, Any place I should buy it or are they all the same in quality?
Thanks.
layback
Had good luck with Classic Parts Headlight switches. Just don't
get the cheap $29 one, heard lots of complaints about them:
http://www.classicparts.com/1947-54...6-Volt/productinfo/53-111A/#.UnJZNBUo7cc
There is also the 12v version, probably the only difference
is the cutout contacts.
Denny G
Denny G
Sandwich, IL
I just bought one from the truck shop here in California. It is an original fashioned repop. I installed it and it works fine.
Dennis
His dad is the wholesale importer of a lot of the parts that we
get from the vendors. Good chance that they are all imported by
him, I just can't feature multiple manufacturers tooling up to
make a very limited volume item like an AD head light switch.
Just had this conversation with a good buddy this week. We both
feel that the vast majority of the reproduction parts are
sourced from the same manufacturers.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
The best would be NOS AC-Delco.
The repop switches are fine, it's the repop knob/shaft that stinks. The knob is held onto the shaft by a set screw and, in my experience, will fall off every time you pull on it.
