| | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | I have shared in a previous post that I have a few mystery holes in various places inside and outside of my '48 Chevy 1/2 ton p.u.
I am wondering what I am on seeing on the passenger side door post...
I have the original standard data plate on the driver's side door post fastened in place. In addition, on the passenger's side door post, I have 2 mystery holes that appear to be for another data plate. These holes would have gone in the opposite corners of those in the original data plate as it faced out. In other words,if you flip the data plate face down, the holes fit perfectly. Any idea what was going on here with those 2 holes? If these old trucks could just talk to us!!! | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 |
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Yes RH drive, I can't quote the page but it is mentioned in the 1954 Factory Assembly Manual. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There might be an ID plate on the right door pillar of the cab on RH drive cabs, but it is not shown in Section 1, Sheet 10.00 HINGE AND IDENTIFICATION PLATE INSTRUCTION in the Factory Assembly Manual. It might be shown elsewhere in the FAM.
A part number for a RD 6000 series ID plate is listed on the above page/sheet.
| | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | The right hand option makes sense. I wonder if anyone here on Stovebolt.com has one. It would be interesting to see one pictured, as well as the data plate installed there. I can not believe that many were equipped as a right hand drive. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Right Hand Drive.......you guys amaze me. Good thinking!
Steve H
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Maybe that truck came from Australia (or Japan)?
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Or Oakland ...click... My 50 has two holes on the passenger pillar I thought all the AD's had them Never really looked ...RHD pillar... A RHD cab would have the cowl vent on that side also | | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | My "standared" LH-drive truck was built in Oakland and has resided in the United States all of its life. As DAD stated, do all the A.D. trucks have the 2 holes on the RH door pillar? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There were three "standard" cab "styles" during A-D years:
47/48 (I think) 49-53 54/55
None of my 1954 cabs (pickup and suburban) has the holes on the hinge pillar on the passenger side. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Here is another wild guess
I don't know my trucks history But it was a red truck. With red horn, red fender braces, red air cleaner.
I think it was ordered by a government agency like a city truck or maybe even a fire department. It has a hole for a spot light on the drivers side.
I think fonzs truck was a highway county truck.
My jelly doughnut guess is that chevy trucks ordered by government agencies had the passenger side drilled for a second data plate for gov ID.
| | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | For the record, my '48 Chevy 1/2 ton truck begain its life as a member of the fleet for the Road Department in Mineral County, Nevada (county seat is Hawthorne). | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | My '51 has no holes on the right hand pillar. The data plate is riveted. My '50 COE has the holes on the right hand pillar and the data plate is held by two small sheet metal clutch head screws.
Kent | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | 1950, 3604 unmolested - No holes in the right hand 'A' pillar. Two small clutch head screws fastening plate to left pillar.
DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | So would it perhaps make sense that the assembly plant location may also play into the story? Certain plants produce both LD/RD trucks as we now have a 50' with no holes? Could this be due to proximity to port facilities? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | my understanding is right drive vehicles for export were assembled in Canada, is there any indication they were produced anywhere in the US?
Bill | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I think fonzs truck was a highway county truck.
My jelly doughnut guess is that chevy trucks ordered by government agencies had the passenger side drilled for a second data plate for gov ID. That is exactly what I was thinking. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | None. Just that I know Luke's truck was a gov't vehicle and that my '51, which does not have them, was not.
I think your info is heading down the correct path, Brad. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | here is a pic of a RHD 50 firewall with two dataplates ...link... | | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | I do not know how this plays into the conversation, but my truck was purchased by the Mineral County Road Department from the local dealership ("Nevada Garage") in Hawthorne, Nevada. | | |
