0 members (),
278
7
Mod | | | Forums66 Topics128,078 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Hello!
I think the shift box on the steering column was unique to 1955 first series, the lower lever has a dog leg bend in it. I have attached a picture of mine in a mocked up state but I am pretty sure the lower shift rod is on the wrong side of the lever. Can someone please confirm this? Thanks.
[URL=http://s1035.photobucket.com/user/mendonjo/media/image_zpsee65c53a.jpg.html]Photobucket[/url]
1955 First Series 3100
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The shift box on your truck is from a 55-2 V-8 truck and all 56-59 trucks. The stock shifter box for 55 both series 6 cyl trucks has 2 straight arms and a bell crank on the bell housing with 2 levers for 2-3 gear selection. Probably the previous owner made the swap. Fred
| | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Hi Fred,
Are you sure about that? The 55 first transmission was different than the 54 or the 55 second (if it wasn't for T Lederman I never would have found the right transmission).
Any other 55 first series guys out there with a stock drivetrain?
Joe
Thanks, this sure is a great group!
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The box I put on my Suburban came from a '55 first GMC. Both levers are straight. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Thanks Bill.
I looks like even the length of the arms is different too (distance from centerline of the arms where the linkage connects to centerline of the shift mechanism)
Joe
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, likely because of the different routing as mentioned by Fred above .... and the pic I linked shows the arms correctly positioned, both on the top side of the levers ... also the arms from the box to the trans [via the bell crank] are quite different from the later ones, and maybe you have the whole later setup
Bill | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The transmissions are essentially the same from 55-1 (open driveline) through 61. The main differences are the side covers for the 55 6 cylinder trucks where the 2-3 shift lever is clocked up and the 1-R is down. Later trucks have both levers pointing down and use the shift box with the dog leg. Fred
| | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Thank you so much for responding to this post. I would have been in a world of hurt trying to figure out why I couldn't get the shifting to work. I got the shift linkage you saw in the pictures with a 55.1 six engine i bought but it was mated to a Saginaw via some cobbled arms on the transmission itself. Actually the only thing that was in the truck that was left of the three-on-the-tree setup was this shift box. It was mounted on the steering shaft and not hooked to anything. Go figure. Luckily I bought another shift linkage set for my truck from our member Nels54 so I probably do have the proper parts. Thanks again guys.
Joe
