2 members (Otto Skorzeny, joe apple), 64 guests, and 4 robots.
Topics128,089
Posts1,056,139
Members48,435
I have two 261s, one is a late block with the new style water pump, etc and the other one is a '54 model (3703414) and it has the high mount water pump on it. I'm just learning about these engines and so far I thought all the 261s had the new style water pump. Did the early ones use the same style pump as the earlier 235s? If so, which years? Its possible this engine has an adapter plate on it for that pump but I really can't tell for sure.
1950 4100 - unrestored and driven weekly for almost no reason at all.
3B Offline
Hy mechanic58, the first two years of 261 production (54-55) had the "high mount" water pump, the same water pump the 235s of the same years had, hope that helps.
The 261 high mount pump looks like a 216/235 pump but has a larger lower hose connection.
My Blog
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
It is possible to use a smaller-truck water pump on any 261 (if you want to use a smaller-truck radiator).
Of course, you would have to match the year/style of the pump to the block (or use an adapter plate, if you have the 54/55st block).
Thanks for all the information.
