| | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#98203 11/22/2006 3:23 AM | Joined: Oct 2006 Posts: 22 Junior Member | | Junior Member Joined: Oct 2006 Posts: 22 | Surely a dumb question. I can ground my steering column and the horn works. I put the horn button retainer (new) on and nothing works. The retainer seems to have no movement. I have the spring between the steering wheel and the column. Is there a spring between the retainer and steering wheel. I am unable to find an assembly view......Thanks for the assistance | | |
#98204 11/22/2006 6:28 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You might get a better response if you tell what your truck is. There were a few different setups for horns over the years. | | |
#98205 11/23/2006 1:07 AM | Joined: Oct 2006 Posts: 22 Junior Member | | Junior Member Joined: Oct 2006 Posts: 22 | great idea...1958 3100 stepside 235ci/3 speed 52000 mile original | | |
#98206 11/23/2006 1:58 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there should be a diagram in the assembly manual, tho it was written for 55 and the 55/6 wheel and column is different - there is a spring on the contactor that fits in a hole in the wheel and makes contact with that retainer, which itself provides the 'spring' for the button
your symptoms indicate that something's wired wrong - the column normally provides the ground for the horn when the button's pressed and that contactor completes the circuit
Bill | | |
#98207 11/23/2006 4:56 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The spring is built in the button retainer. You should be able to press on the fingers & blow the horn. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#98208 11/24/2006 5:49 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | I had some problems with a vehicle that the column didn't ground and had to scrape some paint off the place where the bolts attached the column to the dash.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
