1 members (k2handyman), 74 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#98203 11/22/2006 3:23 AM
Junior Member
Junior Member
Surely a dumb question. I can ground my steering column and the horn works. I put the horn button retainer (new) on and nothing works. The retainer seems to have no movement. I have the spring between the steering wheel and the column. Is there a spring between the retainer and steering wheel. I am unable to find an assembly view......Thanks for the assistance
#98204 11/22/2006 6:28 AM
You might get a better response if you tell what your truck is. There were a few different setups for horns over the years.
#98205 11/23/2006 1:07 AM
Junior Member
Junior Member
great idea...1958 3100 stepside 235ci/3 speed 52000 mile original
#98206 11/23/2006 1:58 AM
there should be a diagram in the assembly manual, tho it was written for 55 and the 55/6 wheel and column is different - there is a spring on the contactor that fits in a hole in the wheel and makes contact with that retainer, which itself provides the 'spring' for the button
your symptoms indicate that something's wired wrong - the column normally provides the ground for the horn when the button's pressed and that contactor completes the circuit
#98207 11/23/2006 4:56 PM
Riding in the Passing Lane
The spring is built in the button retainer. You should be able to press on the fingers & blow the horn.
1972 Chevy c10 Cheyenne Super
#98208 11/24/2006 5:49 PM
I had some problems with a vehicle that the column didn't ground and had to scrape some paint off the place where the bolts attached the column to the dash.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
